btlfed7
So I have been reading alot on setting pinion angle and got a little confused. Almost everything I have read says to set pinion angle with the bucket on the ground with full weight, but I see a bunch of rolling chassis with the rear set in place. I am assuming that the pinion angle is set later adjusting the clevis's. If that is correct, then in what position on the rear housing do I weld the housing brackets?
Sorry if this is a dumb question, I think I did to much research and confused myself.
