Gerry
Seems that they work with old style stuff, but you need to be careful with the new tyres.
It appears that the latest tubeless MTs and Hoosiers are not suitable for this tyre of balancing system. Due to the STICKY compound they use the inside of the tyre, the Dyna beads will stick in one place and stop them from rotating to the place they are needed to balance the tyre.
For wider tyres like mine (18.5"wide) I suggest you contact a Dyna bead distributor.
