It can be pretty tough to get a recommendation on carb settings that will actually work in all instances. When you look at all the variables that come into play with something like tuning an accelerator pump circuit, about the only way to get ir right for you is to test, test, test.
For those of you with solid lifter camshafts, hook up a vacuum gauge and take an idle reading. Now bump the timing up 2 and take another reading. Now retard it 4 and read it again. Now change your valve lash by .002. See all those different numbers? That vacuum level is what the carb is depending on, just to work at all, and look how you've affected it.
I always get a kick out of guys that hammer and bang on carbs, whilst running a motor on a dyno. Heck, leave me in the dyno room alone for two minutes and I'll find you a lot of power and never touch the motor. If you're looking for magic numbers, that's easy to do. But a dyno is a static environment, whereas different cars have different weights, different gear ratios, different torque converters, etc. Toss in varying barometric pressures, temperatures, grains of water, etc. and it's a wonder we can ever get a carb to work in so many different conditions.
Your best bet is to buy one of the Edelbrock kits with the different metering jets, step-up rods and springs. Find an afternoon where you can spend some time playing and see what your car wants. Standardize your tests, so you're not trying to drive uphill on one test and downhill on the next. And do it all in one afternoon, not one day when it is 76 and the next evening when it is down to 48. Change one thing at a time, so you can always come back to where you were if it goes wrong. It won't take long before you make the motor happy.
