Bill Griff
I have had to change the gears in my Ford 9 to accommodate my cam/engine setup. I purchased a 4.11 ring and pinion set from Summit along with the installation kit. After all the installation I get to the point of setting the backlash and found that the corner of the ring gear interferes with the material surrounding the pinion support bearing. I have found a few sites that suggest grinding down the material around the support bearing. Another site suggest grinding down the corners of the ring gear teeth. Do you guys have any suggestions?
