From what i been reading, you might not need it at all. Pull it off and see if it centers up.
Hey: one of our original members had the same problem with his 'Spirit'.??
humm. I'm going to call them tomorrow.
Here is a photo of my set up. It is short by some standards but I drive on good roads and don't take it off-road. If so, than it should be longer because you would need more suspension travel.Anybody have a sketch or photos of a panhard rod on a front axle? I'm thinking that may be the problem with tracking on my bucket. The car feels solid when you push on the tires or body but when you hit a bump it might be a different story.
Thanks
Nice photos and a nice car!
It would seem that with your quarter eliptic springs, it would be necessary to have Panhard rod to keep things centered. With a typical transverse spring you would think the spring would become the Panhard rod except if the shackels cause some side movement. I think I will try one and see what happens. If there is no improvement I will just keep it there. If it hurts things, I can remove it!
Thanks.
Some time back there was a big debate on one of the T forums (could have been this one) about the value of a front panhard. I decided to experiment and took the panhard off of my Spirit front end. There was a slight difference in the feel of the car, especially cornering. Without the panhard, the car didn't feel as "tight" and tended to wander ever so slightly on bumpy roads. It seemed I couldn't carve a turn quite as precisely as with the panhard. I put it back on and the car steers as if on rails... very sports-car-like. I'm a believer in front panhards.
HMMM, I have a Spirit chassis and I didn't use the panhard bar. Drives like a sports car, but I'm running a little wider tire on the front than most. What helped mine the most was Toolman's process for squaring up the axles.
The Tub T, which has cross steering, is downright scary without a panhard rod or a dead perch. I went with the latter, for a cleaner look, but either one will work.
