akitagandy said:
			I want to use an I beam and a spring behind I like that look and not a lot of chrome
My bucket has a custom spring behind on an original Ford I-beam. No chrome.
I said custom because my spring mounts to the sides of original 47-49 dogleg split 'bones on brackets that I designed and built.
Spring over perch- Your spring sits on top of the perch and is retained only by the u-bolts, with the full weight of the car plus road loads on those U-bolts. You can lower the car with spacers, but have to cut the perch to raise the car.
Spring under perch- The weight of the car sits on top of the spring, and the bolts just retain the spring when the car is lifted. You can raise the car with spacers, but can't lower it without modifying the perch.
Spring over axle- more traditional design original Fords were built this way, requires a heavier drop axle to bring the frame down. Allows drag link behind the axle where it belongs. Keep Ackerman correct.
Spring behind axle- give cleaner front end, hides the shackles, allows less drop in the axle while still getting the car down low. usually (but not always) requires front mounted drag link which usually (but not always) means the ackerman is off.
If you don't have alot of fab skills, stick with one manufacturer and the parts that were designed to fit togethor. This usually means a long build time if you are on a budget.
If fabrication is your forte, then find you an axle and go with it. It is important to know your skill level.  If you can't weld, or know someone who can, then go with a kit manufacturer's parts.
If you can, then make it work.
