AndyMenon
[attachment=5066:GEDC0012a.jpg][attachment=5067:GEDC0021b.jpg][attachment=5070:GEDC0032c.jpg][attachment=5069:GEDC0042.JPG]
Hi all,
I just finished hooking up my fuel line. As I have a late model 305 in my ride, I put in a Holley black electric fuel pump with a Holley fuel pressure regulator to match.
Here are a few pictures of my set up. The pressure gauge is showing a residual pressure of 1.8psi. I noticed it a couple of days after I finsihed the fuel line. I unbolted the gauge, and let it bleed until the needle fell back to "Zero", and bolted it back up. But again, after a few minutes the gauge was back to showing 1.8psi!
Here are the facts:
Thanks much!
-Andy
Hi all,
Here are the facts:
- As seen from the fuel-pum shot, the gas tank isn't in yet.
- The pressure gauge was bolted to the carb inlet weeks before I completed the fuel line
- To leak test the connections, I poured some rubbing alcohol down the fuel line until it pord out from the other end of the hard line, before I tightened up all the hose clamps. There is some amount of fluid in there.
Thanks much!
-Andy
