Fuel pump SBC
My T has one very similar and it works very well. I am running a 302 with a 600 cfm holley.
I did not read a pressure in the description. You may need a regulator if it is much over
7 pounds.
it should work if your carb and cam are not to big. but you should check the pressure some of these pumps are intended for fuel injection and you will need a regulator. racer
