RPM said:
Oh but it will, I hardly ever run the electric pump. The mechanical pump does just fine for just cruising up and down the roads. Now it won't maintain good pressure if I run it hard, fuel pressure will drop. That is when I use the electric to run it hard. I don't want it to lean out.
Let me rephrase that statement I made...........UNDER Most Conditions, A manual fuel pump won't pull thru a pulsed type fuel pump, but will pull thru a rotaryvane pump. It will still allow fuel flow past.......but, enough for what you want?????? Maybe, maybe not, depends on what your doing......like what RPM says......If ya got a blown double carbed engine that won't tolerate anything below5.0 PSI without falling on its face.....I'd say no.........you can read between the lines here I hope............
If you gonna run both, match them close to the same flows, etc. I've been building race stuff for well over 25 years, and alot of folks forget about fluid dynamics and the physical laws that apply to that science................they pull all the thought into traction, the engine, the suspension, the trans, and the fuel system......they put a big pump on there with a filter and call it good, then call me when when the engine leans out mid track and oils everthing down within about a 200 yard radius............
On the street, it isn't critical, unless your at really high altitudes, then things change slightly...............
Under most circumstances....a stock pump is plenty. A stock mech. pump with a elect.booster, great.................
ME? I don't like mech. fuel pumps......there's a metal arm rubbing on a dawm cam lobe in there rubbing.........no roller, OR, a metal pushrod riding on a camlobe pushing on that metal arm.................they're mounted down there by the exhaust where they can be nice and toasty on those 100 Degree days when your trying to cruz, getting even more heat thrown to em, hey, whats not to like.........
they're durable, they're great, they're fine and they work, mostly trouble free, are a great asset to the human race.................but I don't like them...........just my preference on the matter..........I'll take a crank driven pump anyday!.......:lol::lol::lol:
Gotta go......a big Tractor with about 4 or5 motors on it needs someone that can do the blower belt boogie.......its sick and running a fever.......and I gotta go catch a plane.............I'm outta here.............
