Gas cap
That center "button" should pop up. Is there a key for that slot in the center? Maybe just a small screwdriver. A lot of motorcycles use that type.
Can you take a picture with your phone when you're on Google? It might be able to tell you a brand or who makes it.
The closest picture is the one I took and I found no markings. Since it's a critical item and I only have a 1/4 tank left I'm taking it to a rod and custom shop nearby. Thanks for the help
Thanks for the help guys. I didn't have any luck using a wide screw driver as a key. Knowing it is probably a motorcycle type item helps a bit. Since I need to get gas in it, I'm taking it to a rod and custom shop nearby. Time to get some professional help
BTW, I really dislike my handle "T Totaler". When I did it, the name sounded cool but after setting it up I realized that it reads another way...as a person who totals T Buckets :) and I certainly don't want to be that person. Any guidance on how to change it?
If you go to your name on the top blue banner. Go to Account Details. You can change your username and provide an explanation why. Hit submit. If you recently created your name, I think you have to wait a month or two before being able to change your username. 👍
