Great Gasser Look! All you need are some coker cheater slicks, small round tank in front of the radiator. Looks like the front springs are mounted on top of the axle or the frame mount is high....Does it have a straight axle up front? It looks cool! Have a big cable driven tach and some old 270 Degree sweep SW gauges up on the cowl, sweet....and a bunch of old school decals, Erson cams, M&H RaceMaster, Accel, etc, etc....
I Like mine lower, but I like the look....is that 2x4's under the front and rear of the body on the outside of the frame or is that metal tubing? Looks like thats the body mounts from the looks of things. You could always make the mounts to the inside of the body to clean the lines a little.
