Ok, Here is my problem:
Car gets spark to all cylinders... I checked distributer and coil and all is good.....
I checked compression to all cylinders and they all read at 110..
Gas to carbs.... Push gas and fues squirts into carb...
Fuel pump is electrical and opperates when the switch is in ACC or run...
When I turn over the engine it acts as though it wants to start. As long as I keep the ignition switched turned to START the engine will ruin and I can press the gass and get the engine to revv.
AS SOON AS I ALLOW THE IGNITION SWITCH TO RETURN TO THE .....RUN.... POSITION, THE ENGINE DIES.
I cant figure out why... any ideas?????
505-250-4547, John
505-250-4547, John
