OK, heres the question. Dd you set up your drive line angle and pinion angle with the rear solid trans mounts? If you have aplasma machine OR a torch, your looking at 30 to 1 1/2 hours minutes cutoff and reweld time of trans mount depending on your setup.
Now, if you already have all the driveline set up, I'm with Ron, redo your rear crossmember to drop the trans. When you do this, your gonna have to redo your pinion angle. If not, your liable to have a bad driveshaft vibration if theres a misalignment.
I always say 'Measure 3 times and cut once, it doesn't take as much time to do it right than to redo things'....ALWAYS THINK 3 STEPS AHEAD! When building a car, something always interferes with something else....
Theres no quick way to do this, unless you redo your front motor mounts solid....then you will have to put up with the vibration. If your a hardcore racer type....it might be your cup of tea....
Best bet is to cut and reweld your trans mount, using the correct mount, then if your rear has a buggy spring you can use a spring taper shim to correct your pinion angle. But that will also mean cutting your hairpin/4-link or parallel bar brackets where they weld to your rear, unless you have adjustable ends.
