KPoole9008
I am wanting to put windshield squirters to squirt water in front of my rear tires. I want to do burnouts [i'm reliving my teenage years] without putting too much strain on the rearend. I have all the pieces to do the job. I have changed washer pumps and the new one leaks to, so it's not the pump causing the leaking. The water tank is above the squirter nozzles. Gravity causes the water to drip out of the tank thru the nozzles when the pump is turned off. I need some type of valve that will keep the water from leaking out. The tank is mounted in the rear so I need something that is electric or that will let the water flow in one direction and not leak. Any ideas?
