rooster57
I see a lot of posts about shocks . I saw this front shock mount at a car show last week and thought some of you might would like to see a different idea. I took the pics with the I phone i hope you can see them. The shock upper mount was a stainless rod threaded the bent to the height and shape. welded to a plate and he welded it to the frame but it could be bolted. The lower mount was a plate using the spring pivot bolt and he drilled another to keep the bracket at 90 deg to the shock. These look like a very easy fab with very minimal welding for the guys who dont weld so much.
