In dash shifter...
cisco64
I had a customer owe me some money and he ended having to give up his bucket to cover the debt. Anyhow, I am trying to go through everything now. Check out the picture of the shifter in the dash...does anyone else have this set up??? bucketdash.jpg
What motor and tranny does it have? I saw an in dash shifter on a car show recently. Good lookin car how about more picks.
Motor is a 350...like I said...still going through everything....dude wasn't too happy in having to let it go...ill post more pictures tomorrow, I hadn't seen this set up before...was curious if anyone else had anything similar...thanks for the reply.
That is interesting. Cable hook up? Does it run inside the car or through the fire wall then under?
More leg room floor room is hard to find in these.
I had one of those in my seat riser. No real shifter, no gate, just a lever attached to a long Morse cable to the tranny. Works fine as long as the tranny has good detents to hold it in gear.
Corvair, Dodge pickups used in dash shifters. I built my own version and mounted it next to my right leg on the seat riser. It has gates and neutral safety switch. I will load pictures if interested.
Terry aka dirt t
Here's mine It uses a Morse cable.
Having a problem loading pictures.
