Is Anyone Using LED Headlights ??
I do quite a bit of driving in the T at night & I'm not too impressed with my headlights so I'm thinking of converting my halogens to led.. Has anyone done this & if so are you happy with the results.. Can anyone recommend a good brand ?
I've been thinking of it but haven't done the homework on them yet. I had a huge issue with the bulbs that came with my new headlights. I could barely see 5' in front of the car and they were super yellow and very dingy. I installed a set of Sylvania bright white bulbs that light up the night. So after that I kinda let the LED bulbs go for now.
These made a HUGE difference.
You might want to check the voltage AT THE LIGHT , make sure you have enough juice , there's a huge difference between 12v-14.3v..
I tried them in my wife's car and they didn't last very long. Hopefully you will have better luck with them.
After more research tonight it would appear it's not a good idea to use led with reflector style headlights as it can cause blinding to oncoming traffic & they would not be as bright as halogen.. Led is better used in projector headlights.. For starters I decided to try these out.. They should be here Friday...
It won't let me post a link to them, I'll post a pic when they arrive...They are the PIAA Extreme White Plus..
Cool! Be interested in hearing what you think about them.
I will post photos of my new led lights...…..
Speedway Part # 91061001
Does anyone have a suggestion on how to mount these headlight brackets from Speedway that have not mounting holes?
Strange. When I bought mine from Speedway several years ago, they were ready to bolt on. Maybe even less bucks.
Look here I found the lights after I installed them......Brights lights on my fence at about 65 feet...20181212_165001.jpg 20181212_165001.jpg
Do they fit a seam beam housing? Part number?
Yes Indy they went right into my Headlight buckets...…..I got them on eBay, look for Jeep 7 inch headlights..try them you will like them...…….
We don't have any JEEPNEYS in the T-Bucketeers!!
I used the United Pacific 31379 7" Crystal Headlight.. Looks great... Available all over the internet but I bought mine at The Daytona Turkey Rod Run..
Will do, thanks !
Is the front lens glass or plastic?
Plastic me thinks...….
I suspected that since the back side is plastic. I guess it's going to have the same problem
as all modern cars today with oxidation, might need to apply a clear coat for protection.
