Just another home built T sort of..
fuzzy
Looked at my profile and noticed I posted a thread in 2010, wow how time flies. Anyhow My latest project is a 23 T, scratch built frame and body. 110 inch wheelbase , body is longer and wider than typical T bucket. But typical sbc engine and other stuff.
Got more done. Mounted Camaro shifter. Built seat and mounted dash and switch panel. Had to modify brake pedal ofr more leg room.. Finished the steering shaft with quick release adaptor.
More work done. Mounted fuel cell, pump and lines. Mounted simulated bed.
Looking more and more roadworthy every day! :thumbsup: How will you address the gap between the bed sides and the rear of your body tub?
Plan on installing a roll bar just in front of the bed. Should make the gap less noticeable.
Here's some photos of a Triumph tr7 interior.
