akitagandy
Does anyone know about Lt1 aluminum heads and will they fit on early model 350 and are they worth buying $300
I myself, would not run Alum heads on the street, (even if they gave them to me) hard to get the right head temp for one thing, because you are not wanting to run your engine at 240 plus, like the stock engines do, just a smog thing... Plus you have to be very careful not to use any stainless (bolts, etc. and any threads need to have the correct lube, anti-seize) on or near those heads... IMHODoes anyone know about Lt1 aluminum heads and will they fit on early model 350 and are they worth buying $300
I found some info that said they want work without a lot of work, water jackets will dump into the valleyIMO I would skip them and save a few more bucks and buy new ones. There are some really decent ones (better than the old outdated LT-1's) for not much more. Check out Skip White performance. They have some pretty good fully assembled ones (I hear) for $650 (inc. shipping!). That is a bargain!. Skip White I have not bought anything from them, but others on here have.
Mike, You know all the right words to say, and how to say them... Thanks
