Anyone that is running an MSD Ready to run distributor (no box) on an SBC - Have you played around with the different springs and bushings to alter the rate and total amount of advance? If so, what have you found that works for you? I'm just starting to experiment- one change at a time.So far, I've moved the vacuum advance hose to full manifold vacuum (suggested by Putz), and changed out one heavy silver spring for a lighter blue spring. It seems to run a little better but still has a significant bog when I jump on it- I know this may be a fuel delivery problem as well (accelerator pump cam, squirter nozzle,etc.). Anyone want to jump into this can of worms?
