I've said this before but I'll repeat it , on a tunnel ram dual quad setup , when using the rear carb as the primary , you will over fuel the rear cyl's & under fuel the frt's. The savings in gas mileage over running 1:1 linkage is negligible & the driveability actually improves ,albeit slightly.
OK in a open plenum, when the front 4 cylinders go thru their intake cycle, the vacuum pulls you intake charge thru the open plenum, into the lower 4 runners, into the front 4 cylinders. You have to remember the the Chevy firing order 1-8-4-3-6-5-7-2....balances the intake pulses somewhat, in the open plenum, with a progressive linkage.
We've done research into this with sensors in the intake, we've even used the Spintron and strobed the airflow pattern thru a plexiglass window in the side of the plenum.
Our tests showed a weakening of intake signal toward the front cylinders, ie, the fuel/air mixture arrived there, but it took longer. You've got to remember in a Tunnelram that vacuum pulls on a mixture that is atomized, so fluid dynamics in a mist is at work here.
That same signal weakness shows up in a dual plane intake....#3 intake valve is alot closer to your primary throttle bore than the #8 intake valve. And that mixture has to travel a long way in the horizonal plane.
That difference of those 2 vacuum signals in the dual plane, is very similiar to the signal in the TR. The larger the plenum, the weaker the signal. Thats how they came up with the Street Rams, they've dropped the plenum volume. Grumpy, and several others did some experimenting.
The older Scorpion intakes that had the carbs at a angle, guess what! We don't run the same jets in all 4 corners! And we made power to win races! Am I right Mango????
I know we're dealing with street motors here folks, and I'm not ragging on you 2O2F, but the Tunnels are made for alot of cam, with alot of carb. Alot of the time, folks don't realize that theres a big handicap running one of these on the street. You have to adjust and adjust and adjust.
I tune these things day in and day out with dominators, 850 doublepumpers....and even with the the new Killer looking Holleys. Mostly sheetmetal tunnels that are made for 1 thing, flowing air!
The old Weiand and the like, TR1Y's, could be tricky as hell to tune. The best tunnels running on the streets, in my opinion, are the single 4 models. Yes, the duals can be run, but you've got to tune them. And it takes time
