gsspangler
Does anyone know the advantages of a narrow upper control arm on a IFS setup ??? Do you need both upper and lower to take advantage of the benefits ??? I am going to set up the front end in my 27 track T, I have standard tubular lower control arms right now, I can get narrow tubular upper control arms at a 1/4 of the reg. price. Will this setup work ??? how far off will my alignment be, mainly I would think camber would be the most affected. Information found that the stock width control arms length from centerline of ball jt to centerline of inner shaft is 8-3/16 and narrowed is 71/4. Does anyone have any advice. Thank you
