all-world1
I'm doing my engine/trans/rearend mockup without wheels and tires, so I plan on setting my front spindles, frame and rearend at the correct height above ground level for this process.
I'm going to be running 5.60X15 on the fronts and P235/75 15 on the rear. If any of you are currently running these sizes, I would really appreciate your measurements from ground to center of hub
Craig
Craig
		 Build safe, enjoy the ride... PS, if you run a longer wheelbase than 96" I would go a bit higher, so as to NEVER drag the pan or flywheel... :shoot:
