new shifter
putz
Want to replace home made shifter how do cable shifters like B&m megashifter work on t buckets?
I've seen and read nothing but good things about them. Looks like the main advantage is freedom of placement. With a cable setup, you could mount it just about anywhere.
got a B&M Quicksilver on mine and I LIKE it. I got a 3500 stall, full manual trans with reversed valve body. I like the ratchet action that only goes one gear at a time - 1, 2, 3 or 3, 2, 1. and dam near impossible to hit neutral or reverse.
Those tall Genie or Lokar shifters look good but WAY to easy to miss a shift. I like to slam it in there and not worry about where its going.
BT
