Gerry
With the other thread on the 350 I thought someone maybe interested in this.
The T has the case only of the 350 in it for set up. When we come to build the trans I am going to put a level plug in the casing. Reason is I dont want a filler tube on show, especially hooked to the firewall.
So when we do the build is it worth me taking some pics and posting them? This can be applied to other dip stick trans but you may have already worked it all out for yourselves.
For the guys that want to check the level on a regular basis remember if it needs topping up when you check it, its probably got a leak.
Gerry
Gerry
