Been thinking about the tank a while. I really don't want to mount it to the radiator so am thinking of the firewall. The distance shouldn't matter should it? The expanded water pushes out to the tank then as it cools is pulled back to the radiator, right? BUT...my over active mind says... the vacuum when cooling might not be strong enough for the distance so over many cycles it would just lose water through the overflow tube. I just don't KNOW. Is this one of those "try it and see" things?
