Thanks everyone for the kind words. I was very nervous about doing it and had some help from a fellow buckethead who did his own about three years. He didn't touch the spray gun, just stood back and would shake his head yes or no. Biggest issue I had was getting the gun adjusted just right. Once I got that master, hell, it's easy (wouldn't want to do it for a living, but would definitely help the next buckethead who wanted to try it).
Next step is wait about a week for the single stage acrylic urethane to really harden, then tackle the flames. I will use a gray Scotch Brite pad to scuff the area where the flames go and then lay out the design. I will then mask everything off and take about an ounce of clear and "a pinch" of bright white pearl (just enough to make the clear look a bit milky) and shoot the flames. If it works, I should have just a hint of silver ghost flames ... should work, I've watched enough YouTube videos to make your head swim!
Then, wait about another 72 hours, take the gray Scotch Brite and lightly go over whole car and then shoot about 4 to 5 coats of clear. Wait another 72 hours, 1500 to 2000 wet and dry sanding paper and then cut and buff (same stage Thomas is at right now ... he might be done by now).
THEN, get the sucker back together and start logging some miles!
