By two position does that mean simply on/off?
You don't want headlites or tailights thru the ign. switch . you don't want the horn thru the switch. You do want turn signals , fan, ign. fuel pump thru the switch. You can use relays to energize any/all circuits so a low load switch can handle a high load circuit/s ..
I personally would not recomend an electric WP on the street
I deleted all the circuits that didn't apply to your question. Most of my circuits are relay controlled as you will notice in the wiring diagram.
I did leave the Anti-Theft switch in the circuit, that along with the FP switch are required to start the car and drive it very far. I also have a fuel shutoff ball valve. That will NOT keep them from pushing it onto a trailer and stealing the car thou.
All of a sudden I can't upload files, there is NO button. So sorry, I was going to upload a pic of the wiring diagram. If it gets fixed I will upload at a later date. I might be able to PM the wiring diagram if you like.
Try downloading to Photobucket and then uploading to here.
Jimk
