As they have told you , the coolness factor is up there with the EFI, BUT, you gotta deal with all the wires andboxes that on certain EFI's are hard to make attractive.
Its a good setup, has a lot of adjustability, and is the only way in my opinion, to deal with the crappy fuel situation that now exists. Don't get me wrong, I love carbs and can tune the hell outta them, but where we are with fuel and parts, its getting easier to do the fuel injection.
Add to the fact that the EFI adjusts itself on the fly to optimize things, fuel mileage goes up, power goes up, and this is even at altitude, going thru the mountains and below sea level.
Theres also a learning curve also, so, that has to be taken into consideration. Adjustments are fast usually, add your software to your laptop and adjust it out. Theres no dis-assembly to change jets, messing up your gaskets from repeated removal. All in all, EFI is the future, and they even come looking like carbs too....for the folks like me that like that look.
Once your dialed in, your good to go until a component goes....but thats with all things.
Just make a good looking loom, keep all your mounting neat. Recently did one for a T with a Ford Mountain Motor in it....made a dressup cover that bolts below the dual throttle bodys, and TIG'ed up a all alum. econo rail type scoop covering up the throttlebodys and alot of the wiring. It kept people guesing whats under that cover, but with the coil packs on the valvecovers and that extremely mean rumble and throttle response, folks knew it meant business.
Its all as cool as you want to make it....
Even made a chromed louvered cover over the computer, split loom covers the wiring. I like running some of the wiring thru brass or copper line....that can be polished up nicely.....
