i have never set up a 1/4 elliptical setup, but i to am condidereing this type of suspension...  it looks simple, and straight forward..I've done some research on it after i seen this setup on a car in bowling green..
the biggest thing would be if you have a chrome axle you need to come up with some kind of mounting bracket from where your existing spring perches mount, or some way to bolt the bracket on to your axle and locate it so it doesnt spin.. if you dont have a chrome axle and didnt care to scuff up your paint, you could drill a hole, insert a piece of tubing and weld it into the holes you drilled (
Posie Quarter Elliptical Spring Kit) and that would give you a place to bolt the shackles... on your frame mounts, i would mount them parallel with the frame of course..  your spring weight, which you will want to be as close to begin with, you could remove springs with the speedway/posies kit cause i'm sure a T is pretty light compared to a full fendered car. pretty sure you adjust the final ride height with the large bolt on top
Posie Quarter Elliptical Spring Kit.  you dont need a panhard bar with this setup..
on a couple other forums you can find many threads on this setup, and there is a very good one on the jalopy journal forum.. alot of people use trailer springs and cut them in half. they make their own frame brackets and just use spring bolts to mount but i dont see any of them with ride height adjustment though.....  you could go as far as using your spring you already have, keep it cool when you cut it, and just make a couple of 4 hole nounts and use standard 1 3/4 spring bolts..
heres a link to a pic i took of a frontend on a car using 1/4 elliptical springs and friction shocks..
http://www.tbucketeers.com/forum/vbpgimage.php?do=full&p=602&d=1213500388
