i need some advise ,
i am building a RHD chasis, and with a 350 chevy engine as the power plant, i have little room for the steering shaft, and can not fit the steering box by the bulkhead.
The steering box is a corvair as i need a rhd unit.
if i use this as cross steer , does it matter if the drag link is not parrallel to the tie rod?
does anyone make a straight steering arm?
will i need a panard rod, if so will this come frm the spring perch , or better from the other side of the chasis.?
re the tie rods arms what thickness of metal should i fabricate these from? 1/2 or larger?
best wishes Adrian.
best wishes Adrian.
