Good evening guys, I do have a rack and pinion frame mounted in my bucket, it works fine, I do not have any bump steer at all! We did however have wheel hop that was a sob to solve but got it done. The wheel hop was mainly caused but piss poor tires and getting a good balance job done right. I have 6000 miles on a set of motorcycle tires when we took them off and replaced with Hoosiers and tires looked good when we took them off
The most important thing on R&P system is getting it level with (Full loaded weight) all the way across from steering arm to steering arm, you can not attach the rack tube higher or lower then the steering arms. I also have the Chevy metro rack which has a shorter tube on it, which gives it longer steering rods, as mentioned, longer the rods the better. You also must run a panhard bar and it too must be level or as close as you can get it. These are just a few things we had to work with when installing the rack.
I have talked with PotvinGuy about his rack and his problem, his rack is a different manufacture then mine and also he has the Rack Tube mounted inside the front tube of the frame (if I remember right) that said it is very hard for me to see if the tube is level with the steering rods. I might add it is a Beautiful Car, in fact seeing a picture of his car encouraged me to put a rack in my car when we were building it!
If it were me I would make sure it has a level plane all the way across and also level out the panhard bar, I think it would work better, since the rack tube is mounted in the frame tube and there is not much for adjustment on the tube it self, I would have Ron (RPM) make some new steering arms and bend them to the proper height to level the arms to the rack tube. That is if it is in fact bump steer, it makes me wonder if it isn’t wheel hop, that is the way mine acted 30 mph you could feel it, 60 mph it would shake the whole dam car but you could walk though it, I did not see if it came back a 90 mph. That was all fixed with good tires and balancing.
The reason that you don’t see much of it on IFS is because it is just what it says, independent front suspension not a solid axle!
I am building a new bucket and we will be putting a R&P in it as well, I like them, a little quick on the steering but that can be changed by ordering a different ratio rack and longer steering arms which we will do on the new one!
Hope that helps,
Jerry
