Track-T
when is a steering box not a steering?
To save time.....It's not a steering box when it will not turn the front wheels.
Took the box apart to check everything out. put it back togeather and made sure it was adjusted right.
installed it back under the cowl and dropped the wheels back on the ground.
steering works great with wheels on stands but not even going to turn sitting down.
front end is well lubed.box is adjusted correct. now i,m looking at the pitman arm, it's long at about 16"
the shaft from the box to the pitman arm is about 10". arm to front end is about 45"
not sure what i'm missing here, I would think even sitting still it should turn somewhat.
no pics tonight....i'm not home
