Corley
To anyone with experience here...
I've tried drilling holes in glass in the past, with bad results. That is, the glass cracked out from the hole just as the drill bit went through. (special V shaped diamond coated drill bit for glass.) I gave up on that process.
The other day my wife wanted me to experiment with etching some patterns on glass, since I was doing some sand blasting anyway on the Model A parts. So she taped off an image of a humming bird, and I hit it with the sand. Turned out my nozzle and sand were a bit too much for the glass, and really cut into it almost immediately, making a depression of about .020" or so. Also tore the tape up pretty bad... I guess that the amount of blasting that it takes for rusty metal is way to severe for etching a pattern on glass.
It got me to thinking that it would be pretty easy to drill a hole in glass using sand blasting, if it didn't cause it to crack and break.
So, the question is: has anyone tried sand blasting holes in glass, and what would the correct proccess be for that, or is it a no-go. Something like a small windshield wiper hole would be nice if one could accomplish it easily with sand blasting. Curious minds want to know!
CB (AKA Corley)
PS I sand blasted some brass windshield slinder pieces that came out a beautiful brass patina. Do you suppose if I coat that with a paint clear coat it will stay looking nice?
CB (AKA Corley)
