baddawgcustoms
I'm still on the fence as far as what style suspension to run on my T. I like the simplicity of the "standard" suicide design, the old school look of running bones, and the correct geometry of running a 4 bar. My question is when running the split bone setup, how do you set the caster, other than the angle in which the rear of the bones are mounted? Or bending the axle? I want to run a four bar setup, just because i want to be able to align the car better, and I've read so much about simple changes in caster, and toe, that change the way the car rides and drives, I will definitely run adjustable style rods. I just happen to be curious about the adjustment on the bones. Someone educate me!
