Gerry
Hi
I have been looking at dampers (hydraulic) for the front of the Fad. Cant find any maker that can supply one in the size I need. I have asked a few BIG names and they just say cant help or we can make a one off with the customary HIGH price. So I looked at industrial damper because there is no reason they cant work, at least in my mind. Found one company that makes them from 6 inches long to over 3 feet. They are adjustable from 30 N to 1800N and have mechanical stops built in. Sounds like a winner. Now comes the crunch. They are expensive so after looking at two I decided to think about one fixed between the opposite ends of the opposed springs. That is to go right across the front from bell crank to bell crank.
This will mean there is going to be a time when one wheel moves up exactly the same amount as the other one moves down; and the damper does not work. I figure that with the leverage on the bell cranks this is a 1000 to 1 chance.
What do you guys think?
Will one do instead of two?
gerry
gerry
