I have found that a lot more steering boxes can be used in the side ways position, this way pitman arm moves in and out to give more tire clearance in the left turns... Why I have not thought about that before, I was too stuck on/with old ways of thinking, (boxes mounted in same old ways) the box is mounted like a stock front steer mount, sideways, but farther back, and the pitman arm repositioned,,, but I would have to run a U joint this way, which I am not crazy about, as the more goodies you have in between the box and steering wheel, the more play you sometimes get...
