steering stops
Track-T
You guys running steering stops, Where are you mounting them.. If I turn full right I'm into the spring shackel, full left into the steering arm.
Jim, if you look closely at the attached picture and look at the second bolt down on the left side you'll see an adjustable steering stop.
Perhaps you could do something similar on your car.
thanks, jim
I like that a lot Jim. Clean and Simple. What more could you ask for?
George
After looking over the different ways to do it.... I got lazy because I didn't want to take things apart.
I went and drilled and tapped the axle.
"Satin Nickel" rattle can from Home depot.
