Throw out bearing clearance
cootertwo
Hi all, I'm still working on my new to me T Bucket kit car. 5 speed manual, with hydraulic clutch conversion. Yes, I've bled the system. The only way I can get the clutch to disengage enough to shift into gear, is to have a lot of "pre-load" on the throw out bearing. I'm old school, and old, but there has to be clearance. I've read some places that a pre-load is required, and that the newer throw out bearings are designed to ride on the pressure plate all time. I call BS on that. Right now, I have a 7/8" master, and 7/8" slave. I have a 1" master to try, and a pull type slave coming to tinker with. There is a possibility that something isn't right with the clutch arm and the pivot, etc. etc. ? Please tell me I'm not cwazy for insisting on some free play on the clutch. I'll do some measuring later, but looks like I'm getting at least 1" movement at the arm. First thing I'm going to do is see how much movement my slave has, and go from there.
From your description, you do not have enough throwout bearing travel between fully released and fully engaged.
I can see two ways to go;
1. Dive in, do the math and select components that match the physical dimensions and load bearing requirements.
You will need to consider the following: Clutch pedal length, ratio and travel, Master cylinder bore, travel and mount, Bellhousing dimensions, clutch fork dimensions and ratio OR if internal, throwout bearing dimensions and internal sizing. If using a fork, the throwout measurements and the slave cylinder bore and travel, Flywheel and clutch type and size, along with released and engaged lengths.
2. Call the companies that have done all that and have them select matching components to assemble into a system that works for you to purchase.
If you are reusing the flywheel, clutch, bellhousing, fork, pedal, master or slave cylinders, you will need to provide them with the identification of these parts. There is no getting around this, you must know what each part is being used or replace everything.
The other option (?) is to ask a bunch of goofballs online and get a bunch of different answers and choose one or a mix of the answers. This will provide no guarantees or after sale service and tech help. Unless the responder also has a T-Bucket with the same parts (engine with similar output, plus all the other parts mentioned), they will be guesses.
I agree that a clutch should release fully and have enough travel to move the throwout bearing into contact with the clutch and engage it enough to provide a gap between the clutch and disc that is in the specifications and allows proper shifting.
I tried to find a decent video for you. There is a ton of AI slop and very generic videos from India.,
This one seems to cover the basics.
Thanks, I just need to get under there, and try to see what's what. Hoping to avoid pulling the engine, to get to the clutch assembly. I have one of those scope camera things I can run into the side opening of the bell housing, and get a pretty good look at the internals. I'm old and feeble, so appreciate any advice, good or bad, and sort things out from there. I'll get-r-done soon. This is going to be my sorta daily driver. Love the wind in the face, and I don't have to put my feet down at red lights or stop signs !!! Ha! I have a pull type slave coming tomorrow. Looks like it may have more travel than the push slave I have now. We'll see. ;)
Interesting video....https://www.youtube.com/watch?v=ZfM95ZFLxWM
I used to have a old Chevy truck with a STOCK juice clutch. It worked great!! It had an external slave cylinder pushing on the fork instead of the typical clutch pedal push rod and a dual reservoir brake/clutch master. What do you have? Stock parts cobbled together or a mix of aftermarket parts? Like what was said before, you're going to have to identify every part that you have either for us or for the parts guy (or gal) . PICTURES would help a bunch!!
Point one - The travel length is helpful.
Pint two - Well, there you go, that specific setup does require the throwout to ride on the pressure plate.
Point three - He points out that length of travel varies depending on where on the fork it's measured. That's that ratio that is so important!
Provided that your parts MATCH the ones shown, this should get you enough to troubleshoot.
I'll mention something else that is different between brake experience and hyd clutches. It's not obvious until you think about it.
Brakes have a lot of extra margin of safety built in. When everything is properly set up and adjusted, the pedal only travels part of the full stroke. Even a power brake pedal still is not going to the floor. This means that when bleeding, you push more fluid through the system and it will take fewer pumps to fill the system. It also gives you the feedback he mentions. On a clutch, the system is designed and sized so the full travel is used every time. The master only pushes enough fluid to move the slave, no extra. So it take a lot longer if you are bleeding using the pedal and you don't get that feedback. This is why using a power bleeder or vacuum bleeding has a higher success rate. You are able to move more fluid.
OK, "Finally" got my problem solved. I installed a 1" bore master, replacing the 13/16" that was on it. Now I have a lot more movement. Plenty enough to leave some clearance for the throw out bearing. Now hunting a return spring to put on the clutch arm. Also, might take the spring out of the slave cylinder, see no need for it, and interferes with the clearance adjustment. ;)
I have used hydrolic clutch mechanisms before. You actualy don't have free play. The pedal has a slight movement before moving the pressure plate. The master cylinder pusher has to let it up past the small hole to relieve the line pressure. The slave has to have the ability to move back to let the clu t ch all the way out pluss the free play for wear ect. If its all bled and pedal is adjusted you will have to increase for of master or decrease bore of slave. Linkage has to work so it pushes the master all the way as does slave. In other words when it all works right you should be able to push the thow out bearing back by hand so it doesn't touch the pressure plate but it should stay in loose contact while using. The fluid adjusts the action like disc brakes. No adjustment after its all set up right. If you over tighten the master push rod it won't let off pressure though the little hole and it will pump up.
On brakes this makes em lock up as they get hot. I hope this is understandable. I know what I mean but don't always convey my points.
The smaller the MC piston the easier it will be to push the pedal, but the longer the travel will be at the pedal.. Less travel at the clutch fork.
On the other hand the bigger the MC piston the harder it will be to push, but the longer the travel will be at the clutch forks.
If you want both advantages then you will need vacuum power assist. It's no different than a mechanical linkage.
It's physics, unless you are the president
You’re not crazy for wanting to see proper free play, because in a normal hydraulic clutch setup you still want the release system to have a defined resting position rather than riding the pressure plate all the time. Some modern concentric setups do run with light constant contact, but a conventional throw out bearing system should not be heavily preloaded or it will overheat and wear out quickly. If you’re needing a lot of preload just to get disengagement, that usually points to geometry issues like incorrect pivot height, mismatched fork ratio, wrong slave/master bore balance, or even clutch stack height rather than anything “normal” about the bearings themselves. Before swapping masters and slaves further, it’s worth confirming the mechanical leverage and clutch fork travel, because excessive preload on the throw out bearing is usually a symptom, not the fix.
Just an update.... I'm too lazy to look it up now, but I found a you tube video, showing 2 different pressure plates for the SB Fords. One for mechanical linkage (cable), and one for hydraulic activated. The picture showed the fingers of the mechanical plate extending further out than the one for hydraulic. Looks like the hydraulic one was designed to work with less movement. ??? ;)
You’re not crazy for wanting to see proper free play, because in a normal hydraulic clutch setup you still want the release system to have a defined resting position rather than riding the pressure plate all the time. Some modern concentric setups do run with light constant contact, but a conventional throw out Angular contact ball bearing system should not be heavily preloaded or it will overheat and wear out quickly. If you’re needing a lot of preload just to get disengagement, that usually points to geometry issues like incorrect pivot height, mismatched fork ratio, wrong slave/master bore balance, or even clutch stack height rather than anything “normal” about the bearings themselves. Before swapping masters and slaves further, it’s worth confirming the mechanical leverage and clutch fork travel, because excessive preload on the throw out bearing is usually a symptom, not the fix.
while some newer clutch systems tolerate light constant contact, a traditional setup still benefits from having a bit of free play so the throw out bearings aren’t continuously loaded and generating heat. If the clutch only disengages with significant preload, it usually means something in the geometry or hydraulic ratio is off rather than the TBS bearing design magically requiring pressure all the time.
