pinky-t
DRILL PRESS
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly painted project which you ahd carefully set in the corner where nothing could get to it.
WIRE WHEEL
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard earned calluses from fingers in about the time it takes you to say," Oh,S--t! "
SKILL SAW
A portable cutting tool used to make framing studs too short.
PLIERS
Used to round off bolt heads. Sometimes used in the creation of blood blisters.
BELT SANDER
An electric sanding tool commonly used to convert minor touch-up jobs insto major refinishing jobs.
HACKSAW
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes;.
VICE-GRIPS
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH
Used almost entirely forlighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW
A large stationaary power tool commonly used to launch wood projectiles for testing wall indtegrity.
HYDRAULIC FLOOR JACK
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside.
TWO-TON ENGINE HOIST
A tool for testing the maximum tensile strength of everything you forgot to disconect.
PHILLIPS SCREWDRIVER
Normally used to stab the vacuum seal under lids or for opening old style paper-and-tin oil cans and splashing oil on your shirt, but can also be used, as the name implies. to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER
A tool used to make hoses too short.
HAMMER
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the mosst expensive parts adjacent to the object we are trying to hit usually smashing the thumb that is holding the object that you are trying to pound into whatever it is that you are working on effectively eliminating the need for a manicure care on that thumbnail for weeks. See 'Son of a b*tch TOOL'
SON OF A B*TCH TOOL
Any handy tool that you grab and throw across the garage while yelling, "Son of a b*tch " at the top of your lungs. It is also, most often, the next tool you will need.
Enjoy
WIRE WHEEL
SKILL SAW
PLIERS
BELT SANDER
HACKSAW
VICE-GRIPS
OXYACETYLENE TORCH
TABLE SAW
BAND SAW
PRY BAR
HOSE CUTTER
HAMMER
SON OF A B*TCH TOOL
Enjoy
