ElderTee
Hey Guys: Have had the old Elder T, now, for a little over a year and it's time for a total re-wire. I am looking at the Painless 8 circuit Modular specifically made for T's. I'm only wiring for the following: headlights, turn signals, brake lights, four way flashers, fuel pump, alternator, starter and dash guages/Tachometer. I have installed a Petronix ignition. At this time, The voltage regulator and starter relay are attached to the fiberglass body and wire grounded to the frame. I am thinking of remounting both items directly to the frame. Question is..would I still have to ground the units via ground wire? I am also installing a grounding block which will serve as grounds for anything requiring grounding. I am a novice and have never attempted a project of this type, but figure that the car is mine and I should know what is what and where it is and how it works...Any suggestions on an electrical board would also be appreciated. (Photos would help immeasurably) I will be mounting this circuit board under the drivers seat. ANY and ALL information or suggestions would be greatly appreciated... Tom Burns, Inverness, FL
