bentbaggerlen
There instructions that come with the gages are about useless, even one of there techs said so. He told me how to set the Speedo for my ford sender, that info is not even in the instructions. And that the button used to set the speedo should never be preesed while the car is moving, again nothing in the instructions about that. So I set the speedo to low and I still have the same problem The speedo hangs up when it gets to CALCing and that's ware it stops... OK I'm just about done venting...
Has any one had any luck programming there TPI Tech speedo, Any hints you can give me ? I'm ready to pull them out and replace them with something else.
If you make such a quality product why are your techs always busy? O.k. now I'm done venting, but don't ask me about the windshield wiper I got from Speedway...
