AltBantam
I was searching past posts on underfloor brake and clutch pedals as I was wondering if they would give me a little more foot room. I found an old post from Hotrod46 from 2016. It was one of the last posts by Hotrod. He posted a photo of a homemade brake pedal which appeared to be made using a curved steel rod or tubing. He stated the rod traveled through a hole drilled into the floor. The fact he has no posts after Jan. 2016 troubles me. The question I have, and maybe someone else knows, how to calculate the arc of the bend of the rod so the rod passes though a hole slightly larger than the diameter of the rod? At first I thought if might have to do with the arm length the curved pedal is welded to. But the arm appears longer in the photo. Perhaps it's an illusion. Any thoughts?
![brake pedal (1) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG brake pedal (1) [640x480] (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG](https://tbucketeer.com/data/attachments/19/19912-9c4424d7cc5d29f74b8d9831148ec228.jpg?hash=nEQk18xdKf)
![brake lever and pedal [640x480] (2) (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG brake lever and pedal [640x480] (2) (2015_11_13 11_07_31 UTC) (2021_01_12 08_56_11 UTC).JPG](https://tbucketeer.com/data/attachments/19/19914-f0ad11fee53c624637952d34a40eb21e.jpg?hash=8K0R_uU8Yk)
