engine24355
Okay, as mentioned in my spark plug gap post, I have discovered an issue with coolant in the combustion chamber. This is obviously a big issue that requires some work (blown head gasket or worse). However, I have a golden opportunity to make some upgrades (assuming nothing wrong with the block etc.). I have even been approved by the wife to make an upgrade and I have not even gotten the engine torn down yet (only partially). In her words "if you have to take off all those parts, why not put better ones back on?". I love this women! Anyway, I have been thinking about a top end kit to really boost the numbers on my 350 SBC. Right now it is pretty stock with a dual carb set up and a mild cam. I would like to go to a single carb set up and change out the cam etc. I am trying to stay on a reasonable budget here so I wanted to ask for thoughts from you guys. Trying to stay around $1,500 or so for this upgrade so I would appreciate any advice. How about it, what would you do?
Thanks!
Thanks!
