Hey I didn't know that was Ex-Junks diagram. I saw it on the t bucket alliance.Thank You Track-T, this is perfect...
Can someone put a relay diagram on here as to which wire goes where for a fuel pump and fan?Hey I didn't know that was Ex-Junks diagram. I saw it on the t bucket alliance.
The following are simple, easy to follow diagrams which will enable you to wire your T Bucket. These drawings are for a GM system using a one wire alternator. Study the drawings for a while to give you an idea of where the wires go and why they go where they do. I followed these and did my car. It was my first time doing a car. If I can do it, YOU CAN TOO!
Special thanks for these go to EXJUNK.
oh oh ,me bad..Thats ex-junks wiring. (old sucks)
Yes, damn fine drawings, man who truly understands his topic makes it simple for those who don't. We had this once before, I think, small oops on the first dwg, the R terminal on the solenoid connects direct to the coil so as the ballast resister is by passed when cranking. OR Use an HEI and forget the R terminal connection altogether.I liked this drawing better
You can purchase a "How To Wire Your Stret Rod From Start To Finish" from Speedway Motors about $8.00. A great investment.Hi All,
Does anybody have a basic schematic wiring diagram. In lieu of recreating the wheel, I thought I would check first.
Thanks,
Steve
