I have an Auto Meter gas gauge with the Auto Meter sender installed in a new tank (thanks Ron Pope!) but am unsure of the wiring. The Auto Meter instructions say:
1. Connect a wire from the terminal post on the sender to the gauge.
2. Connect a wire to a ground on fuel tank to the gauge.
3. Connect a wire from ignition switch to positive terminal on back of gauge.
I am ok with #1 and #3 but my question is about #2 - the ground wire.
Before finding these instructions, I ran a wire from one of a bolt on the sender to the chassis as a ground. I also have a ground from a bolt on the filler neck that is on the tank to the chassis and a ground from the base of the filler neck that is on the fiberglass body to the chassis.
Do I need to...
Replace the ground wire attached from the sender base to the chassis with a wire going directly from the sender base to the gauge
or
Leave the sender grounded to the chassis and add a ground wire from the gauge to the chassis
or
Leave the sender grounded to the chassis and add a ground wire from the gauge to any mounting bolt on the tank
or??
The second option would be the easiest for me because of access but I want to insure that is correct.
Signed,
Electrically Challenged
Do I need to...
or
or
or??
Signed,
