27 t bucket weight?
Mine weighs 1937# with 50# more weight in the rear. It has a Chevy 350 with a Turbo 350 trans.
Mine is 1980# with Ford 302/C4 trans and 14.8 gal gas tank full....
..Now that was before I made some changes to the body this year but the weight should not have changed much...........
Mike
2220 lbs. Heavier than most because of the 409 and 114" wheel base, but I'm going to guess that if you only want the weight of a 1927 it is probably going to be more. A friend had his '27 weighed at GoodGuys two weeks ago and I think it was 2580 lbs. (all steel body).
1550 -ish last time I checked, but mine's stripped down no interior, no reinforcement in the body, etc. Frame, engine trans, and a fiberglass body sitting on top.
1765 pounds with a 2.3L Ford Pinto OHC.
#1985 with a full tank (20 Gallons) of gas and no driver. SBC and a 350 turbo with a tri-5 rearend.
