Welcome to Our Community
Sign Up
Dismiss Notice
27 T something
Discussion in 'Project Plans & Updates' started by scott haley, Nov 8, 2018.
  1. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    That's gonna be a cool ride, Scott! Nice work. Can't wait to see it roll under its own power. :thumbsup:
  2. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    Information Technology tech
    slow
    radiator mounted
    headers exhaust slow
    Spanky, choppedtop and James Louis like this.
  3. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
  4. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    Nice job on the raised steering box mount.
  5. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    Good work, Scott. Slow and steady wins the race! Keep it up :thumbsup:
  6. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    James Louis likes this.
  7. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    Looking good. Are catalytic convertors required where you live?
  8. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    i dont know. im running a stock 1995 4.6 and the injection system with oxygen sensors. i want the engine to run just like it did in the 95 t bird. i built the truck to have them. im not changing anything that runs the engine and transmission. its from the tbird too. AODE i think
  9. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    ill put the oxygen sensor bungs on tomorrow.
  10. MMC757
    MMC757
    Expand Collapse
    Apr 28, 2021
    101
    52
    Gender:
    Male
    Occupation:
    I get paid for what I know
    It is possible to trick the PCM into believing a cat is present by using a MIL eliminator if you really wanted to.
    Its basically just a resistor in the signal return wire. Very easy to fabricate but even easier just to buy for pretty cheap. Much cheaper than a cat.
    Just search "Ford MIL Eliminator" and tons of sources will come up. Just find one that matches your connectors.
    [​IMG]
    rbsWELDER and Spanky like this.
  11. TheYeti
    TheYeti
    Expand Collapse
    Oct 20, 2019
    173
    185
    Gender:
    Male
    Occupation:
    Mechanic
    A bit of research should give you a few sources where you can mail your PCM to have the emissions junk tuned out. They will eliminate PATS too so you don't need the chipped key.
  12. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    its it alive about 3 weeks ago
    ill take the thunderbird hens nest wiring that i am slowing working on
    i crank it every day after i cut and move wires
    im using the cats because thats what i said i was going to do 4 years ago
    it is built to fit them where they are.
    sounds good so far
  13. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    I swapped a 2007 Mustang 4.OL v6 into a 2006 Miata. The P.A.T.S system will not let the fuel pump & fuel injectors function without an acceptable chip code . Don't know if this is the situation with a 1995 Thunderbird. Does the Thunderbird's ignition key have a chip in it ? Are you using the Thunderbird's P.C.M , E.C.U or E.C.M ( THE ELECTRONIC BRAIN ) If so ; both have to be used together. Unless you have the P.A.T.S removed from the TBird's electronic brain.
  14. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    I went to e-bay & searched for a 95 T-bird ignition key. Looks like your key is a non transponder key. Looks like you ignition key doesn't have a chip in it. Looks like you have a clear path through an electronic nightmare. Way to go mon ami.
  15. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    no chip YES the 1.95 key is nice
    but the t bird column will not be used
    i bet the miata runs fast
  16. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    Never got it running. After 10 years of struggling with the wiring , i sold it.
  17. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    i had the engine running 4 years ago when that pic on the first page was posted while this thing was in wood form
    lot to do
  18. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    If it hasn't been run since then, I'd treat it as a new engine. All new fluids, prime the oiling system, etc.
    Kevinrevin and rbsWELDER like this.
  19. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    i cranked it and shut off not really running it.
    i primed it before the 1st crank 3 weeks ago
    gonna be alittle bit before i run it again
  20. scott haley
    scott haley
    Expand Collapse
    Sep 15, 2018
    54
    42
    Gender:
    Male
    Occupation:
    i have steering column and master cylinder mounted
    running brake lines slow
    no real good pics
Share This Page
SSL Certificate
