4 bar spacing
OptimusPrime
For those of you running 4 bars on your front end what is the distance between the bar top to bottom?
5 to 6''' on most. Depends on what your using for axel and frame mounts.
The batwing on my front axle has 5" spacing between hole centers so front bare spacing will be 5". The rear axle brackets have 4-3/4" spacing so rear bar spacing will be 4-3/4". So. the bar spacing should be the same as the axle bracket spacings.
Mine are 4 1/2" center to center on the front bars.
