On a spring behind front suspension, with 49-54 Chevy spindles, is it OK to set up cross steering with separate arms for the tie rod and drag link? If that is OK, would it be OK to run the tie rod in front of the king pin line, and the drag link behind?
With setting the frame as low as I hope for, with the typical common arm for tie rod and drag link behind the king pins, I'm running into all kinds of conflicts.
